Objet : ACAD MAP 2025 French DISPO
Hello
YOUPEE avec les versions 2025, nous gardons le format DWG 2018 !!
Les Nouveautes AutoCAD 2025 en Francais :
https://help.autodesk.com/view/ACD/2025/FRA/?guid=GUID-07450FCA-16CA-4D7A-8EA2-9CE842631D75
Voir aussi :
https://blogs.autodesk.com/villagebim/2024/04/nouveaute-les-nouveautes-autocad-2025.html
Eric GUELEN >> Voici la liste des problemes corriges dans la version 2025 ainsi que dans les jeux d'outils
Voici les Nouveautes MAP 2025 en US/English ...
https://help.autodesk.com/view/ACD/2025/ENU/?guid=GUID-25537E3F-6C11-4076-BAA3-93BC090F4443
QQs Trucs interessantes :
-- Support de la nouvelle Geoplateforme IGN
-- Ajout des connexions FDOs Geopackage
-- GEOCARTE (_GEOMAP) sur Imagerie ESRI et OpenStreetMap ESRI
Bye, lecrabe
Quality improvements
-- Delete multiple FDO data connections simultaneously using the Connect Data dialog box.
-- Newer versions of FDO providers are now supported:
PostgreSQL 15.4 / PostGIS 3.4 for FDO PostgreSQL/PostGIS
Microsoft SQL Server 2022 Standard and Enterprise Editions for FDO SQL Server Provider
Easily search and locate layers by their names using the new Find Layer option in the Display Manager shortcut menu.
Improved performance when opening drawings that contain a large number of disabled layers from Raster, WMS, or WMTS connections.
The following customer issues have been resolved in AutoCAD Map 3D 2025 toolset.
Split/Merge Feature
MAPFEATURESPLIT now accurately retrieves the correct geometry for split features.
MAPFEATUREMERGE now works as expected.
FDO ArcGIS
The "Property 'OID' was not found" error no longer displays when reopening a drawing with ArcGIS connection.
Connecting to FGDB data with table names containing special characters such as "ä" no longer causes AutoCAD Map 3D to freeze when using the ArcGIS provider.
ArcGIS Online: AutoCAD Map 3D can now connect to ArcGIS Enterprise portal with Cross-Origin Resource Sharing (CORS) settings.
Style Editor: An infinite scale range value in Style Editor is now accepted in localized versions.
MAPTOACAD Command: MAPTOACAD now correctly exports the features in industry model drawings with FDO WMS connection.
Coordinate System: The "Unknown error" message no longer displays when adding a custom coordinate system to a category in the Coordinate System Library.
FDO FGDB: Some connected FGDB datasets using the FDO provider are now correctly displayed.
Industry Models
The EL_CIRCUIT form now opens as expected when working with specific Oracle-based industry model data.
AutoCAD Map 3D no longer crashes when zooming in and out while multiple structure internal windows are open.
When ordering attributes in the table view, the search functionality continues to work as expected, providing accurate and relevant results.
The Reverse feature now functions as expected for DWG-based LRS industry models.
AutoCAD Map 3D no longer crashes when running COGO Split function for DWG-based industry models.
FDO WMTS: Certain WMTS servers that previously had readability issues are now working as expected.
Ce sujet de discussion fait référence à la publication sur https://cadxp.com/topic/61278-acad-map-2025-french-dispo/
