Tous les fichiers d'aide en ligne Autodesk
La mère[1] de toutes les listes d’URLs à avoir :grin:
[!note]
Les URLS données ci-dessous concerne la dernière version (2027). Il se peut que certaines ne soient pas encore effectives. Dans ce cas remplacez le 2027 de l’URL par 2026 :slightly_smiling_face:
help.autodesk.com/view/3DSMAX/2027/FRA
help.autodesk.com/view/ACADWEB/FRA
help.autodesk.com/view/ACAD_E/2027/FRA
help.autodesk.com/view/ACCESS/FRA
help.autodesk.com/view/ACD/2027/FRA
help.autodesk.com/view/ACDLT/2027/FRA
help.autodesk.com/view/ACDLTM/2027/FRA
help.autodesk.com/view/ACDMAC/2027/FRA
help.autodesk.com/view/ADSKMCP/ENU/
help.autodesk.com/view/ADSTPR/2027/FRA
help.autodesk.com/view/AMECH_PP/2027/FRA
help.autodesk.com/view/ARCHDESK/2027/FRA
help.autodesk.com/view/ARENDERING/FRA
help.autodesk.com/view/AVRF/ENU/
help.autodesk.com/view/BDS/2020/FRA
help.autodesk.com/view/BIM360D/FRA
help.autodesk.com/view/BLDSYS/2026/FRA
help.autodesk.com/view/BUILD/FRA
help.autodesk.com/view/C3DGO/FRA
help.autodesk.com/view/CFG360/FRA
help.autodesk.com/view/CIV3D/2026/FRA
help.autodesk.com/view/COLLAB/FRA
help.autodesk.com/view/CONNECT/FRA
help.autodesk.com/view/COORD/FRA
help.autodesk.com/view/DATAEXCHANGE/ENU/
help.autodesk.com/view/DOCS/FRA
help.autodesk.com/view/DRIVE/FRA
help.autodesk.com/view/FDM/FRA
help.autodesk.com/view/FDU/2026/FRA
help.autodesk.com/view/INFDS/FRA
help.autodesk.com/view/INFMDR/FRA
help.autodesk.com/view/INVLT/2020/FRA
help.autodesk.com/view/INVNTOR/2027/FRA
help.autodesk.com/view/INVTOL/2027/FRA
help.autodesk.com/view/MAP/2027/FRA
help.autodesk.com/view/MBXPRO/2020/FRA
help.autodesk.com/view/MBXPRO/FRA
help.autodesk.com/view/NAV/2027/FRA
help.autodesk.com/view/NAVFREE/2027/FRA
help.autodesk.com/view/NINCAD/2027/FRA
help.autodesk.com/view/OARX/2027/FRA
help.autodesk.com/view/OARXMAC/2027/FRA
help.autodesk.com/view/PLNT3D/2027/FRA
help.autodesk.com/view/RECAP/FRA
help.autodesk.com/view/RSAPRO/2027/FRA
help.autodesk.com/view/RSTR/2027/FRA
help.autodesk.com/view/RVT/2027/FRA
help.autodesk.com/view/RVTLT/2027/FRA
help.autodesk.com/view/TAKEOFF/FRA
help.autodesk.com/view/TNNUINV/FRA
help.autodesk.com/view/TRUEVIEW/2027/FRA
help.autodesk.com/view/VAULT/2027/FRA
help.autodesk.com/view/VAULTMOBILE/FRA
help.autodesk.com/view/VEHTRK/FRA
help.autodesk.com/view/fusion360/FRA
help.contentcatalog.autodesk.com/fr/
  1. L’expression « La mère de toutes les batailles » est une traduction de l’expression arabe « Umm al-Ma’arik ». Elle a été popularisée par Saddam Hussein, l’ancien dirigeant de l’Irak, pour décrire la guerre du Golfe en 1991. Cette guerre a été déclenchée après l’invasion du Koweït par l’Irak en 1990 et a impliqué une coalition internationale dirigée par les États-Unis pour libérer le Koweït. Saddam Hussein a utilisé cette expression pour tenter de mobiliser le soutien et donner une dimension épique et décisive à ce conflit. L’expression est restée dans l’usage courant pour décrire un événement ou un conflit d’une importance majeure ou décisive ↩︎
Savez vous que vous pouvez mettre cette liste en signet?
Savez vous que vous pouvez retrouver l’aide en ligne d’anciens logiciels Autodesk® qui ne sont plus vendus maintenant et qui ne sont plus nécessairement supportés techniquement ? Prenons l’exemple d’AutoCAD® et essayez cette URL:
https://help.autodesk.com/view/ACD/2015/FRA/
En remplaçant le 2015, par 2016, 2017, etc, vous aurez les aides en ligne de ces différentes versions.
